Is there a simple way of balancing up either side a holley carb. I had to adjust mine at the sva test to get the emissions into the uk reccomended levels . Since then I have noted that the exhausts on one side of the inlet feed are red hot while the other side of the outlets are cooler so I must have one side to lean to the other. ( the in let manifold supplies much the same way the bundle of snakes removes the exhaust )
Any one got a simple way of tuneing the mixture screws to balance the mix without the use of analysis tools
If I had a gas analyser I could test the out put through each exhaust until they were the same and this would ensure either side the carb is balanced. Havent got one 1
