Thank you guy's for your input.
Mike,
The reason I'm looking at the commander is that I have access to a new one at a VERY good price so while there is always something better out there this one is affordable.
Roy,
Are you using the throttle body or a multi port system? Did you have any problems setting it up? I'm running a 302 at something around 385 H.P. so I was going to use the 700CFM TB but have since learned that the ECM can be used for either MPI or TB? Not sure which way to go right now. Any thoughts? Thanks
Steve26
