I looked into Imagine, Kinsler and Hilborn. Imagine's largest bore size was smaller than Hilborn's smallest. This should add up to more torque but less revs with the Imagine. Probably just what you need for the street or 302 sized engine. Kinsler was probably the most high tech (magnesium) but Hilborn had the "hands-down" prettiest set-up I had ever seen.
I went with Hilborn with the thought that it would take some serious compute power to tame that system for the street. The next month or two should tell if my formula is correct. The Hilborn is also sized (2 3/16" bore) for a stroked 351. If you have a 302 or something similar Imagine is a better choice. I think they told me it would work with anyone's ECU (Electromotive, Haltech, Motec)
