info needed RCR Tire sizes
Hello, can anyone tell me what are the tallest tires the RCR GT40 will take in the front and rear with out any rub issues? I will be using the 12" wide rear rim, I still don't know if I will be using the 15" or 17" rims. I need the height in inches if possible.
Thanks,
I don't have any measurements but I do have front tire sizes...
For the standard 8 inch rim on the front it is 225-50-15 and it clears by about 1/4" from the sill with the maximum amount of positive castor and ~3/4 degree negative camber.
I replaced the 205-60-15s with these. The rears are 295-50-15's as I recall - but I am now implementing the +2 kit on the rear with the same tires.
