IVA Question
regarding the fitment of reverse light and rear fog light s, looking at the rear light set up being square to the floor does the same apply to the above as I want to fit mine flush into the rear clam.cheers murf.
Yes needs to be square to the floor
Try mounting inside the rear behind the rear vent
Mini 1 is about the right size
next question are there spacers avaliable or how do you go about making rear taillights sit flatcheers.
Steve Dean
Hi Murf,
Also make sure the rear Fog light(s) are correctly wired. They must only be lit when on Dipped Beam or Main Beam. When the headlights are turned off the fogs lights must go off and remain off unless activated again once the headlights have been turned on again.
If this is something you've overlooked then Car Builder Solutions (01580 891309) sell a module (RFLATCH) that takes care of the switching.
Best regards
Steve.
These are the smallest I found and mounted inside the rear vent fairly unobtrusive
Matching reverse light
They are also available with LED innards for a less period correct look
