Lola wheels
I have a pair of 15X9 Halibrands with 2.5 backspace with Lola and Halibrand marked on them. Can anyone help me identify what these were designed for?
Thank you !
Only Picture I have seen of a Lola with Halibrands. Donahue in a T70 Spyder
Fred W
B
I can take some pictures tomorrow, and post them for you.
The one's I have are 15", and 10" wide.
Came off Janet Guthrie,
and Dick Simon's 77 Indy car's.
Cheer's, Curtis
Here is the front, and rear view of the wheels.
Four of mine are 4 pin, and one is 6 pin.
Center hole is 2 1/2".
Not sure that this how you do it But........
I had some one tell me that if I wanted to change the placement of the pin holes,
to thread the existing hole's, and fill with a threaded aluminum rod so that it was flush.
And then re drill hole's to what I wanted.
You might check with some one who know's for sure before doing something like that !
Hope the picture is of some help ?
Cheer's, Curtis
Are these magnesium wheels? Hard to tell from the picture, but is there corrosion occuring (white powder)? Don't think the idea of threaded aluminum rods to alter pin holes is good at all.
Yes they are magnesium,
and there is a bit of surface corrosion.
Not sure if that makes any difference as he just wanted to see the inside of the wheels to compare with his.
I don't think that plugging the hole's, and re drilling is a good plan either.
Just passing along what I was told,
with the prompting to check with some one that knows what their talking about.
Cheer's, Curtis
