Lower front wishbone dimension
Does anyone have the lower wishbone dimensions center to center of the frame side of the wish bone. I have calculated 438.15 mm or 17.25 inches center to center for the FAV drawings. The upper wishbone center to center measurements are 279.9 mm or 11.02 inches. I believe these to be correct.
Thanks Dan
Sounds about right. You need to calculate the actual c-c from the stated jig dim. If you have the same xl print that i got it is for road car (which i believe had bushings inboard) and not the race spec das bearings .
