Hi guys,
I recently tried to start the engine in my SLC for the first time, but it won't start and I'm looking for ideas.
- New LS7 Crate Engine
- GM Performance Engine Controller Kit
- Fuel pressure is 60 psi verified at the rails
- Oil pressure builds to 60 psi with cranking
- Will crank, but will not fire
- Plugs are sparking when removed and grounded, so coils etc, appear good
- Fuel vapor comes out of the cylinders when cranked with the plugs out, so its getting fuel
- DTC P0016 is sometimes thrown ("Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor A)
- There is 4.9v on the plugs to both crankshaft and camshaft sensors
- There is continuity on the signal wires back to the ECM connector
- I replaced both the crankshaft and Camshaft sensors, but the code is still thrown
- Voltage drops briefly to about 8v when cranking starts, but recovers to 10v as cranking continues. The red LED on the GM fusebox stays lit throughout. I tried swapping the battery from my Corvette Z06 into the SLC and it shows the same voltages and same results.
- I pulled the valve covers off to confirm that the valves are moving (i.e. no broken timing chain) and that the valves are fully up when the associated piston is at TDC. I did notice that even with the valves fully up, I can get a feeler gauge under some of the rockers and not others. Not sure if this is normal with an LS engine or relevant to the not starting problem. . .
- The engine controller ordered was for a 2006+ LS7 engine. I don't know how to confirm that what was ordered was what I received?
- The engine has the grey crankshaft position sensor, indicating a 58x reluctor wheel (i.e. post 2006)
Any suggestions or advice gratefully received.
