Terry Oxandale
Skinny Man
I'm not an expert in the SBF, but I've built a lot of them. So when I chose the LSx motor as a powerplant for my project, I figured there would be some degree of re-learning... but jeez, when will it end.
Last week I swapped the clutch pilot bearing out for the Porsche unit, and once that was finished, I moved on to another task. Today, simply by happenstance, I read about a welsh plug that is inserted into the rear of the LSx motors, into a hole that is otherwise open to the crankcase. No big deal I thought, until it dawned on me that the "hydraulic" method of removing a pilot bearing may also push this plug through the crank counterweight, and into the crankcase....which it almost did. I pulled the pan, and there it was, still in the hole (barely), so now I've got to go ahead and push it all the way through, and re-insert a new one into the outside end of that hole.
I can't imagine what I've not learned that will come back and bite me later.
