Lynn Larsen
Lynn Larsen
Cleveland, Ohio (February 2008) Mallory Ignition announces the availability of the new all-electronic advance E-Fire Distributor for Ford Applications.
Designed with a CNC-machined all billet housing, E-Fire Distributors offer all electronic RPM based and Vacuum based advance curves. Select from seven preprogrammed performance advance curves or design your own custom curve. They feature digital rev-limiting and a digital boost proportional retard for supercharged or turbocharged engines with up to 30 PSI of boost, as well as Hall effect triggering and a ball bearing supported shaft for maximum timing accuracy.
The E-Fire Distributor comes complete with Windows-based software and a computer harness for easy adjustability, and it works with any PC (laptop not required). Look for additional models available in Spring of 2008!
Applications:
Ford V8 221-302W - Part #2255104
Ford 351W Elec W/CD C9000 - Part #2255404
Ford 351C-460 Elec W/CD C9000 - Part #2256704
Article at FordMuscle.com
Lynn
