MKII Rear Spoiler Mods
While installing the wireless backup camera on my car, I noticed how much deris was stuck between the spoiler and the body of the car. There are six fasterners that hold this on and they act to press the painted spoiler agains the painted clamshell. Any small debris works it's way into the crevise between the two and starts to scratch the paint.
I took the spoiler off with the thought of placing nylon fender washers between the two surfaces. When disassembling this, I found that the machined receptacle inside the rear clamshell was not flat to the inner surface. The holes drilled in the rear clam were too small to allow the receptacle to sit flush. I also found that the machined outer piece was digging into the spoiler paint.
I went to Home Depot and got a 7/16" drill bit and I found 1/4" x 1-1/4" rubber fender washers which I think will work better than the nylon. These were $0.73 each and I got 12. The 7/16" hole is slightly oversized which allows for alignment issues. Drilling into the existing locations, even with blue tape, caused me some frowns as the edges chipped slightly due to the aggressive nature of the large bit. This is easily covered by the washer and fastener.
