MOTEC injected, No spark or fuel pumps.
When I put my GT away it ran fine. It sat for 2 years. I came back home and hooked up a new battery. Motor turnes over fine but will not start. There is no spark. The fuel pumps do not come on when you turn on the key either. They usually come on for a few seconds when first turned on. I have power to the motec box. Any suggestions? I would also like to find a good MOTEC tuner in the St Louis area.
Thanks in advance
Jim
If its the same as Autronic (same designer)
The internal battery has gone flat and lost all your maps
Reload your tune from lap top.
Jim
If you had it tuned in USA speak to the tuner, they can email it and you can up load it.
If you have made any changes since the tune and you did not save the file it is gone.
If you did save the file then that is what you need to upload, the last file used.
If it came to you from RF programed speak to them.
If the ECU is locked not sure if that will be a problem, If you have ever looked at the maps and made minor adjustments then it is not locked.
Jim
