Mounting UN1 upside down
Question...
Do or have people installed a Renault UN1 upside down thus having the outputs above the input shaft aka like a ZF 5ds-25?
I know the UN1 can have the crown wheel flipped so it could be possible to mount upside down and thus having a setup similar to the ZF box and inverted G50 boxes with the outputs above the input shaft.
If someone has done this before what mods were required? Also if you have done this do you have any pictures showing the drive shaft angles etc.
If I should forget this idea and mounting the UN1 the standard way up can other shares pictures of the drive shafts and the angle they are on ie Flat...or lower at the transaxle or higher at transaxle
Mike Pass
GTD, Renault normal way up, engine down by 4 degrees, 4" ground clearance.
Hi I mounted my un1 upside down when I built my 40 back in the late 1980s. It still works fine on the rare days it goes out. Others have copied the idea probably. I did magazine articles on how I did it way back then. I originally did it to get the driveshaft angles less steep as my engine is as low as the original cars.
That is exactly why I am thinking of do it. Soni can have the engine lower/more original location. Also if I ever decide to upgrade to ZF later on I don't have to locate the engine.
Kevin Box
I've looked at this myself and been in touch with Kev Farrington also
I have the following combo
Canton road race oil pan approx 7.5 inches (190 mm) deep
Wheels / tyres 335 35 17
Inverted this gives me about 12 degree downward half-shaft angle with ground clearance 125mm less with 100mm clearance and this just gets better under bump as the chassis goes down
Non-inverted is approx 15 degrees upward and gets progressively worse as you get into more bump
For my money inverted looks a whole lot better for me but is a lot of work to get there.
Firstly changing the crown-wheel side to side is a little mucking around but the bell-housing is the next issue as follows and depends on what flywheel you are running - l chose 157 tooth Ford so only options 2,3&4 are OK for me.
Option 1
From memory Kev F had an adapter plate from the back of the Ford Block to the Renault bell-housing/transaxle which was inverted. there was also a bit of playing around for the starter. Correct me if i"m wrong Kev
Option 2
Start with an aluminium Ford bell-housing either C4 or Manual and add an adapter plate to back of it approx 30 mm thick. you also need to get a longer input shaft made to match up. This is not optimal option as it shifts the half-shafts back and creates another angle issue. (UN1 ends up about 38 mm further back)
Option 3
Start with a Ford C4 or Manual bell-housing and cut the back off it and weld an adapter to the back of it. Not too hard but would need to be finish machined after the welding
Option 4
Fabricate a bell housing from scratch either from steel or Aluminium. A bit of shagging around but you can get exactly what you want.
I found an interesting article on the web where a Chev block was mated to a Ford Toploader. If you look at the principle it was quite nicely done and could be fabricated in steel or my preference aluminium. Web address below
I have mocked up option 2 with customwood adapter on a C4 bell-housing just to see if it works and ended up with the 38 mm mentioned above.
The current non-inverted bellhousing I have is 139 mm from the block face to the UN1 face. The C4 is 147 mm so by the time you add the 30 mm required to cover the crown wheel 38 mm is where you end up.
I would have to say I quite like the idea of fabricating a custom one in a similar manner to the one on this web site but instead out of aluminium.
I hope this helps ???
regards
KevinB
Thank you KevinB for the info. I was looking at pictures of the ZF 5DS-25 bellhousing and this looks short and the mounting for the ZF is large round mounting face. So was thinking of an adaptor where the UN1 bellhousing mounts thus going from UN1 to a ZF bellhousing with the un1 inverted.
I don't know how long/thick a ZF bellhousing is but it might work out such that the standard ford type GTO Racing single input (quaife) will work.
Kevin Box
I assume you mean this one
The depth is 4.5 inches (114.3 mm) so you could easily make an adapter for the back of it. Either a piece of 30 mm Aluminium plate and some time on the mill or make a plug and get something cast to the right shape. PCD is 11.654" (296 mm)
Excellent suggestion Mike
regards
KevinB
regards
KevinB
You have one already :) nice I need to get me one of those :)
Need this Covid-19 lock downs to pass so business can get back to normal so I can import a ZF 5DS-25 bellhousing and I think I know were you can get an adaptor plate already - after some emails. Will check again. To confirm.
Kevin Box
That is not mine - I will have to buy one
I sent a note to Kennedy for pricing and freight cost along with confirmation it will work with my 157 tooth alloy flywheel and clutch.
Right I can get one custom made locally here in NZ - cost will vary depending on if a single unit for just my self or if I get a mold made up so I can get 5 sand cast up = more upfront cost for me but I could sell 4 others if there was enough interest - to offset the cost and they would be 1/2 has much as just the one off item.
I will have to wait until after the Covid-19 lockdown is over here in NZ so I can get parts shipped to my contact down in the South Island.
Hi guys, sorry for lack of replies/contact but I struggle with computers at the best of times and I have been busy with other stuff as well. I just wanted to mention the breather in the gearbox as it is potentially frustrating to sort out. I originally had it in the wrong position and although on the top the gears were driving oil up a
Not sure what happened their but back to breathers and I lost a lot of oil originally so I opened a channel to the bellhousing in a similar way to how Renault did it and its been fine ever since Mine then goes to a catch tank which drains back into the box just to be sure. I did have it piped to an oil cooler but dismantled all of that years later as it wasn`t needed. Have fun, cheers, Kev F
Kevin Box
Update on my inverted UN1
Firstly I went with the Kennedy 157 tooth Bell-housing as a starting point.
I think this is originally for the Panterra
It is a very nice unit and the cost was not excessive - Refer Pics
I will have a spacer between it and the UN1
The attached picture shows the mocked up version I made from custom wood to check it all worked
The clutch release bearing is concentric and I now have around 5 mm clearance between the clutch and release bearing. - could not achieve this with original bell-housing.
My 3D Fusion 360 (CAD) modelling is completed and has the following - Thanks to a mate Dwayne Holloway
Aluminium plate thickness 40 mm
Spigot into the rear of the Bell-Housing 3 mm
Plate lightened where sensible and machined so it will be possible to use for inverted or non inverted application
Drain plug machined into the bottom of the plate (hope this works)
Breather port machined into the top of the plate. Current plan is AN-08 fitting but not sure what to attach it to????
First Plate to be CNC machined in January if all goes well and no Covid
Also planning to do one piece shaft with helical gear ratio change from Albins in AU - Covid has delayed this but I'll keep working with them
Following the Bob Stoeger - Albins path. - Thanks Bob for your help
Also thanks to Kev Farrington for his initial guidance
My plan is to make a few adapter plates if this is successful - Mike from NZ is chasing me for one.
I'll update further as things progress
regards
KevinB
I have installed an inverted UN1 in my scatchbuilt. I'm happy with the driveshaft angles, but I do have reservations.
I made my own adapter plate, 50mm thick to accommodate the inline clutch throwout bearing, but with the best of effort, I'm still not sure I got the centreline of crank/input shaft precisely right.
I'm also unsure about how oil tight the input shaft will be. It has a seal, but as it may have greater contact with oil, being lower than previously, the seal just looks too wimpy.
As a fallback, I have acquired a Porsche G81 transaxle which I hope may be easier to invert and adapt. I would appreciate any comments.
Install looks good Clive. The Porsche G81 = Cayman GT4 box right? If so they are already right orientation so inverting it will results in 6 reverse gears and 1 forward as I don't think the box can have the CWP swapped like the UN1 can.
Also a mate had a Cayman GT4 and the gearbox was replaced under a recall. Not sure what that was about but I see Holinger do a 3rd gear kit to fix a known issue.
Apparently it is possible to flip the crown wheel on a G81 Porsche box, and Kennedy Engineering are able to provide an adapter plate to a Ford Windsor motor.
A bit of work required to get the backlash set, but doable.
Guess I'm looking for a patient gearbox guy.
