Question...
Do or have people installed a Renault UN1 upside down thus having the outputs above the input shaft aka like a ZF 5ds-25?
I know the UN1 can have the crown wheel flipped so it could be possible to mount upside down and thus having a setup similar to the ZF box and inverted G50 boxes with the outputs above the input shaft.
If someone has done this before what mods were required? Also if you have done this do you have any pictures showing the drive shaft angles etc.
If I should forget this idea and mounting the UN1 the standard way up can other shares pictures of the drive shafts and the angle they are on ie Flat...or lower at the transaxle or higher at transaxle
