I will be required to pass a TSI (two speed idle) emissions test ( idle speed but,not specified,then @ 2500rpm and back to idle not exceeding 220ppm HC and 1.2% CO. First preference for engine is a Carburated 427"FE" probably a Pond Al block w/ Edelbrock AL heads ( at this time I can spec displacement, cam specs ect). Second choice is a FI 427 "Windsor" engine from Roush. Here are the questions....Does anyone know if an FE can pass w/o catalytic converters ( again realise I can spec the cam, carb as I want; even would consider an emissions carb and then a second carb for "after emissions"....If the FE won't pass w/o cats will it pass w/ cats?..............IF carbed FE won't pass w/ cats does anyone have experince w/ a 427 fuel injected Windsor( will it pass w/o or if needed w cats???? I'm in the States and hope someone here or "over there"(where I'm told you Brits need to pass standards this tough or tougher) can help me.....Don't want to have engine built then end up w/ car as "Garage Art"......Unfortunately engine builders here "don't have a clue".....Thanks in advance.....Steve
