Newbie Question about Corvette C5 uprights
Ladies and gents, I'm trying to find a solution to using tubular A arms with Corvette C5 uprights on my car in principle. I've searched here with no specific answers.
I have found the necessary weld-on rings to accept the K727 lower ball joints required for the Corvette spindles/knuckles/uprights (they have the tapered hole in the mounting tab at the bottom- 7 degrees or 1 1/2" per foot taper), but the upper mounting of the Corvette uprights is a ball joint pressed in to the upright. I've found screw in ball joint collars to fit the end of my upper A arms (the collars are designed to accept a screw in ball joint, but that's already in place in the upright), but is there any alternative to having a piece specially machined to go into the screw in ball joint collar in the end of the upper A arm, with a 7 degree tapered hole in it, to accept the ball joint stud of the ball joint that's already in the upright? I don't particularly want to use a heim joint for this.... so how do I join the end of the upper A arm to the top of the Corvette upright please?
Thanks in advance,
K9
Do you have an aversion to using the C5 aluminum "A" arms, i.e., the whole package? After all, GM went to considerable time and expense to design a proper anti-dive, minimal bump steer arrangement, good brakes included.
<LI id=yui_3_5_1_5_1397189943038_574 data-id="55">
Hi, and thanks for taking the time to reply. No, I absolutely don't have an aversion to using the full Corvette set up, but I think I run out of space at the front... That's why I have to use tubular A arms, but want to keep Corvette hubs/brakes etc.
If that's your car in the picture, is there any chance you would be able to measure the width, and length of all of the A arms for me? Just being lazy I guess, but if it's convenient that may allow me to revisit the set up. If the car's put away or tricky to get to, I'll see if I can scare up a 'vette to crawl under..
Thanks,
K9
I gather these arms have not been manufactured yet.
If your upper ball joint is smaller than the lower then you may need to get a machine shop to make the same for the upper joint.
Its only a biscuit with a tapered hole, the 2 tubes merge onto the biscuit.
Like in Al s picture.
The supplier of the lower may help you out.
Am I getting it right as to your problem.
Jim
Terry Oxandale
Skinny Man
Not the response you would look for, but couldn't you design and machine a simple press-in plug/adapter that could be taper-drilled to accomplish what you want? There are no vertical forces on this portion of the upright (sans stiction of the upper arm bushings), so a simple means of securing the press-in plug/adapter could be made.
Paul - I would take Lynn up on his offer AND he may be able to offer some excellent advice on set-up. The picture I posted was a stock, on line photo; I haven't owned a 'Vette since my '66 427 roadster ( wish I had kept it now). Good luck with the project.
A.J.
