Newbie with a T-3 kit
Well I just bought a GT40 frame and body kit made by T-3 company out of Colorado.I haven't found much info on this kit, the t-3 website says the are taking a year or so off to work on projects and the site only has referance to cobra kits.The kit uses mustang 2 front end componants and t-brid rear control arms and spindles.Any info would be helpful Thanks, Roy
i think the kit you bought is the same kit i was consider purchasing. the info i found out was, t-3 is no longer producing the gt40 kits. that mean anything i need would have to be customize. hope the info help
Roy, we are essentialy self manufacturing our GT after purchasing the frame and body panels as are several other folks on the forum, additionally there are a some going one up on us, starting from scratch and bulding from the ground up. Locate other builders in your area to get some help with technical issues and post the sticky situations here for help. The solutions will eventually present themselves.
Good luck with the build.
Brian
