Nissan ZEOD RC Engine Revealed
Nissan ZEOD RC Engine Revealed - Sportscar365Nissan will not only break new ground with the unique electric power plant aboard the Nissan ZEOD RC at Le Mans this year, but the accompanying internal combustion engine is set to revolutionize standards of performance and efficiency.
The Nissan ZEOD RC will become the first entry at Le Mans to complete a lap of the Circuit de la Sarthe under nothing but electric power in June. A single lap of each stint (a fuel “stint” lasts approximately one hour) will be electric powered, then the new Nissan DIG-T R 1.5 liter three-cylinder turbo engine will take over.
The incredibly small engine weighs only 40 kilograms (88 pounds) but produces an astonishing 400 horsepower. The base engine is only 500mm tall x 400mm long x 200mm wide (19.68” x 15.74” x 7.78”). While the engine is technically too heavy to take as carry-on luggage on a plane – it would easily fit inside the luggage guides seen at major airports around the world.
Revving to 7,500rpm, the Nissan DIG-T R produces 380Nm of torque. At a ratio of 10 horsepower per kilogram – the new engine actually has a better power-to-weight ratio than the new engines to be used in the FIA Formula 1 World Championship this year...
