NOS 05-06 Ford GT 5.4 Engine complete.
David Garton
New never installed NOS complete engine, Dry sump with tank, AC, PS, Alt, Super charger, Dual disc clutch with harnesses. On stand always in climate controlled showroom. Located in Spring Hill FL. Cost $41,000 new plus $6,000 core charge. Save over $10,000 first $35,000 plus shipping. PM for more photo's or info. I have became a supporting member and I am having troubles adding photo's and not sure the fix? Thank you, David
Brian Kissel
Welcome to GT40S David. Pictures and proper details are a must for all for sale ads on the forum. Your links to the other forum does not work unless you are registered there. You must comply with the requirements here, or the ad will be removed.
Regards Brian
David Garton
Regards Brian
Brian, Thank you. I have become a supporter and tried to download pictures from my computer prior to the links. I see the loading of pictures are permission only for supporters. I also tried to edit the post and could not find the edit tab. I will fix it when my supporter payment is recognized. Thanks again David
David
From memory and in one of the forum upgrades there was a setting that said you could not post pictures until you had posted 10 times without pictures (at the time the forum was spammed with porn!)
Possibly try posting some text a few times to get your post number up and then the pictures should be able to be uploaded,
David Garton
Please see Video I added to the above listing. It is my personal engine located in Spring Hill, Florida. I still cant add pictures so I put some together as a video and was able to add as a video link. Thank you for any interests. David
