Dumb... won't let me edit my previous post for some reason?? :veryangry:
The pdf link I provided about Audi transmissions in other threads shows the following variations:
5spd Audi 80, 100, 200, A4, A6, A8 is a 012.
6spd Audi 100, 200, A4, A6, A8 is a 01E.
6spd Audi A4, A6, A8 is a 01X.
6spd Audi A4, A6, A8 is a 02A.
Those are the only FWD variations. Rest are AWD or other.
So to me, the 01X or 02A would likely be latest models able to handle more torque, possibly different internals. But what do I know, just a learning newbie. :thumbsup:
Still trying to figure out the model # difference (if any) between gasser and TDI as they apparently have the wider ratios.
I suppose you'd have to look up the specific transaxles as listed for sale such as this one:
http://cgi.ebay.de/6-Gang-Schaltgetriebe-f-einen-Audi-A4-B5-A6-4B-A8-D2_W0QQitemZ270267411002QQcmdZViewItemQQptZAutoteile_Zubeh%C3%B6r?hash=item3eed316a3a
to determine what ratios they actually have. In this case they use the identification of DQS. Which is separate from 01E, etc. No idea how that separate ID plays in? This particular one is listed as coming out of an A6 2.5L TDI .... so I suppose you could look up the actual specs of that Audi model to find out the ratios??
Looking at other listings, this time searching for "schaltgetriebe DQS" brings up http://shop.ebay.de/?_from=R40&_trksid=m38&_nkw=schaltgetriebe+DQS where both use 2.5L TDI V6 motors, one is 1998 and other 2002.
So now... looking up the specs: http://www.audi.de/etc/medialib/ngw...6c5.Par.0005.File.pdf/1998_02_a6_c5_25tdi.pdf it lists the ratios as:
1st / 2nd / 3rd / 4th / 5th / 6th
3.5 / 1.889 / 1.231 / 0.871 / 0.667 / 0.561
reverse is 3.455 and axle ratio is 3.875.
Overall ratio top gear 2.17
Interesting stuff. This is a 1998 model year vehicle. Odd thing is, the AWD version of the 6spd manual has a 4.111 ratio R&P and identical gear ratios as the FWD.
Max HP is at 4000rpm. Other odd thing is top speed for FWD is 218km/h and AWD 216km/h.
If you work it out on the FWD then 218 @ 4000 would be 354km/h at 6500rpm or 219mph.... no idea if 4000rpm is what they use for top speed measurement, maybe it's 4500. Who knows?
I should just use the actual ratios themselves and tire size to calculate it but I'm too lazy right now.
Ok, while we're here, lets check out the 2.8 V6 gasser specs:
http://www.audi.de/etc/medialib/ngw....0007.File.pdf/1998_02_a6_c5_28_28quattro.pdf 1998 model of course.
Scratch that.... show a 5spd with 5th gear as 0.789 and 3.70 R&P ratio. Max hp 6000rpm, max spd 236km/h. Maybe this is the 016 box? Overall ratio 2.92 in top gear vs TDI 6spd of 2.17 overall ratio top gear.
Interesting stuff.
Ok, even more stupid data.... LOL
In 2002 the A6 had a 3.0 V6 gasser. Still, only the 5spd available in FWD. Is this a 016? 5th gear is 0.844 final 3.75 for 3.165 overall ratio. But this motor spins higher to 6300. Top speed 243km/h.
Too many numbers.... if we look at A6 2004 model (6spd!) FWD the ratios are:
1st / 2nd / 3rd / 4th / 5th / 6th / Final
3.667 / 2.053 / 1.423 / 1.065 / 0.853 / 0.730 / 3.75
So overall ratio is 2.74 but this one is electronically regulated to 250km/h. 255hp 6500rpm.
Lets go back to the TDI again for 2004 in A6 and FWD 6spd:
3.665 / 1.999 / 1.407 / 1.00 / 0.742 / 2.984
So overall ratio is 2.21 , which compared to the 1998 2.5L TDI is 2.17 so they are very close.
Summary:
Looks like you want a TDI box for higher speed. Overall ratios didn't seem to change much between 1998 and 2004, however, it looks like they used a ton of different gear ratios and R&P's so best to carefully make sure which model year and detailed specs so you know what you are buying.
One small side note, these all had ASR (anti-skid regulation) and EDS (Elektronische Diff. Sperre). So, if you don't drive a newer VAG car ASR stops the wheels spinning and detunes the motor, EDS is your limited slip differential. But from what I can gather it is the car's drivetrain ECU which modulates the front brakes to keep tire spin under control. Basically it's an open diff and a poor man's LS. Saves VAG putting Quaiffe's in there I guess. At least that's my take on it, correct me if I'm wrong.
Some things are right under my nose: http://www.gt40s.com/forum/how-engi...les-audi-016-083-transaxles-pete-tinucci.html good writeup with 01E supplement on the end.
Oh, and I apologize for this long-winded post. If it's too much just tell me to shut up or something. I guess I'm too "GT40" excited and sucking up all and any info I can find.
Interesting stuff.
Summary:
