L Louis Supporter Feb 13, 2020 #1 Hi All, This attached picture of the original dash in the P1015 has a switch between the toggle switches. Does anyone know what this switch does? Thank you! Louis RCR GT40 MKII Attachments 602876602[1].jpg 282.4 KB · Views: 584
R Ryan L Feb 13, 2020 #2 no idea possibilities Roundel lights? indicator? dash lighting interior light? switched fuel senders between tanks so the driver could check what was left in each tank? Toggle switches are aircraft spec ones and not Lucas 57SA type though.
Z Larry Taylor Feb 13, 2020 #3 Ryan Love said: no idea possibilities Roundel lights? indicator? dash lighting interior light? switched fuel senders between tanks so the driver could check what was left in each tank? Toggle switches are aircraft spec ones and not Lucas 57SA type though. Click to expand... Reostat......used in aircraft etc to dim/brighten the dash lights. Primarily if panel is back lit. Cheers
Pedro Supporter Feb 14, 2020 #5 I believe it is for the instruments lamps, sorry for the poor quality of the attached diagram it is from the SAE papers and it is a little hard to see.
L Louis Supporter Feb 14, 2020 #6 Thank you all for the replies and schematic. Now I know it's a dimmer. Louis
