Frankly, I can't really agree on that and would expect you're all fitting a (adjustable) proportioning valve to the setup.
Dual MC with balance bar just gives a static front / rear brake pressure distribution. This would typically be setup to just make the fronts lock before the rears under hard braking in dry conditions. That way, the rear should not lock before the front in any scenario.
However, this does mean that under light braking (either due to low traction or due to other loads on the car, like cornering), the brake balance is way off.
Consider you'd have 50/50 weight distribution. Under hard braking of say 1G you probably go to >70% load on the front, <30% on the rear. That is how you'd setup the balance bar. For the sake of the rationale, consider the road is slippery and you can only get to 0.1G. Then you'd want 50/50 braking, but you only get 50/20. You're leaving 30% of the potential brake power unused, where you need it the most. Similar for light braking in a corner, you don't want to have that all on the fronts.
