RBT transmission: 6 or 7 bolt? Need help
I am a bit confused. I am in the middle of my build, thinking now about the ZF/RBT transmission.
I am planning to use a -2 and the bellhousing has 6 bolts/holes (picture below) to be attached to the transmission. Does the RBT has a 6 bolt pattern?
I have been searching for some original ZF -2 but the one I have found is a 7 bolt unit. Why is this? Were there 2 different versions of the ZF -2?
Thanks for your help.
Does it mean, Chris, that this bellhousing fits a 7 bolt transmission?
It does not look so when you look at both of them... The pattern on each of them does not seem to fit when you put them together
