RCR GT40 Deluxe Plus Kit For Sale *SOLD*
Status
Not open for further replies.
Why wait 16 weeks for one of FRAN's kits to be produced and shipped? This car is ready to go. All intact with everything listed below, including a brand new from the factory 289 HP Stock Ford Small Block engine. Asking price $41,000. Either PM me or call at 208.320.2519.
Includes Lighting: Pair front high beam headlight, Pair front marker lights, Par rear taillights, Pair license plate marker lights.
Electrical: 20 (street) circuit color coded and labelled wiring harness with integral fuse box and relay circuits.
Gauges: 200MPH Speedometer, 8,000 RPM Tach, Pair fuel level gauges, Voltmeter, Oil pressure, Coolant temp, Senders, Fuel level sending units, Magnetic speed pick up for universal transaxle speed signal, Instruction booklet and support line contact info.
Cooling: Custom aluminum radiator 600HP capable, Pair electric cooling fans, pair coolant tubes.
Accessories: Pair stainless steel door handles, Pair bear claw door latches, Pair GT40 period correct fuel filler caps, Lucas wiper motor assembly, Exterior bullet style chrome mirrors, Parking/Hand Brake assembly with Calipers, Stainless steel brake line system complete with brake light switch, Braided brake lines/hoses, Drive axles and CV joints, Stainless steel body alignment pins.
Interior: Pair of ultra-suede GT40 Nickel grommet seats, Dash Panel, Pedal Assembly, Triple pedal assembly including twin master cylinders for brake system, Brake bias adjuster, Clutch master cylinder, Integrated Heater and A C system, Stainless steel 180 deg crossover exhaust system, Rolling package.
Chassis: Aluminum Monocoque chassis unit, Billet Aluminum rear chassis brace, Ford engine mounts, Chevrolet engine mounts, D.O.M. SCCA Spec. Roll Hoop, Aluminum front and rear body mounting structure.
Suspension: Billet front and rear suspension uprights, Billet front upper lower control arms, Billet lower rear control arms, D.O.M. Tubular rear suspension radius rod links, GM Tie rod and balljoints, QA1/ Carrera custom aluminum anodized coil-over shocks, set coil-over springs, Set GM Corvette performance wheel bearings.
Steering: Custom made rack and Pinjon 2.7 turns with tie rod ends, “D” Style collapsible column, sealed bearing universal joint, Splined quick release unit, Vintage style steering wheel, Shifter assembly (For 016, 01E, G50, or ZF). Brakes: Six piston front brake calipers, four piston rear brake calipers, 11.75” Nascar rotors, Custom aluminum rotor hats.
Wheels: “Vintage Wheels” Halibrand knock-off style 15” X 8” Front, 15” X 10” Rear, Set of three eared knock-off spinners. Body: Nose, tail, roof, doors, Rocker panels, Nostril panel double, D.O.T. Windshield, Lexan headlight covers.
Re: RCR GT40 Deluxe Plus Kit For Sale
Mike,
If the timing of your sale was little better for me your RCR GT40 would have a new home. I keep a photo of #1049 on my wall at work and a 2'x3' poster of #1049 at home to keep me focused on my goal.
I wish you the best with the sale.
Tony
Tony
Thanks for the look, lets change the timing. I will come down on the price or through in more parts. Give me a call.
missing any parts? You have the bundle of snakes SS headers? What transaxle is this setup for? Lastly and corrosion on the parts or car?
Hey Mike,
I just sent you a text.
Buzz, my mother named me this.
Hi Mike,
I've just come across your post and wondered if you sold your kit?
I'm about to place an order for a Superlite Slc in the next month or so but originally considered the GT40 kit so I could be persuaded to swap back.
Best regards
Gareth
Status
