Rear clip support bracket
Doc Watson
I have some photos and basic dimensions for the removable rear bracket that supports the rear clip. Does anybody have good photos (or a drawing) of the bottom plate that joins the lower two location points?. Is it 2mm steel sheet? I need to set up the rear clip to then set the bulkhead on my chassis.
Doc Watson
looks like steel box section in the middle with formed sheet steel at the two ends...
Hi Doc,
Having been through the trials and tribulations of installing a roof spider and the rear bulkhead so I'll offer some simple advice: to set the spider properly you need to fit the front and rear clips, the doors and the windscreen. It's also handy to fit the sills so that the clips and doors sit properly.
I hope that helps.
If you need any help let me know.
Graham.
