I swapped the engine mounts left to right and gained another 1/4 inch forward on the engine so now my axles were only about 3/8" out of alignment with the axle drivers. Next I removed the two rear transaxle mounts and welded up the existing holes and reinstalled them. I cut two 1.5" diameter by 3/16" thick Delran pads on the lathe to fit under the rear transaxle mounts and match drilled two new holes in the brackets. With the rear of the transaxle in place I raised the engine with the engine hoist until it was level front to back and side to side and made sure the transaxle was not contacting the cross member. I then took measurements for "stand off" spacers to go on the motor mounts. I machined four custom spacers and attached the motor mounts with grade 8 hardware. When I released the engine hoist and put the weight back on the motor mounts it was level front to back and side to side.
