The roof is a compound surface, so yes; curved. Or are you wondering about that small profile that most of the fiberglass replicas got?Did original MK1's have a subtle arc to the roof where the spider meets the rear clam...or was this area flat?
Why not save the weight and make them from 1/8” plywood & fiberglass or even aluminum? My thoughts are aluminum as I’m going to Rhinoline the wheel wells anyway but am open to other ways & materials as well.Right now, even without the inner structure, I can open and close the rear clam (with it hitting the locating pins) by myself. The bottom of the clam is set and latches are in place. A preliminary fit of body panels was done prior to finalizing the pin locations. My idea is that when the inner structure and wheel wells are attached to the clam, it will prevent the lower front corners of the clam from flexing and bowing out when the clam is moved up and down during opening/closing.
I’ve gone back and forth on what to make the panels out of. I think I’m going to use the 1/4” plywood and fiberglass 1708 over it.View attachment 146283
Mine came with bonded in inner shell from AKSPORTS CARS.Has anyone added an inner structure or rib to the inside/underside of the spider to hold the arc to the rear of the roof where it meets the rear clam? Right now, mine has no inner structure, which allows it to sag and not retain its shape. Or does the top of the firewall keep the shape to the spiders rear roof area?
The complete inner roof panel? I'm thinking more about the underside of the area that would be between the roll bar and rear clam...if that makes sense.Mine came with bonded in inner shell from AKSPORTS CARS.
