Roush 427 IR
Urs
Hello together.
Is there anybody who has installed to his roush a dry sump?
it s a windsor block . does anyone have cut drawings for measurings?im searching the measurement of a dry sump pan for installing the engine.
greetings from switzerland.
Urs
Hi Urs, for the GTD we've fitted an alloy Roush 427IR to, the chosen drysump solution was supplied by Aviaid as we have had good results previously with their kit. Pump & pan both seem to fit ok.
It's in the car now so not too easy to get measurements from but perhaps the pics will help. :thumbsup:
Urs
hello
thank you for pics!
did you get the enginedirectly from roush with the dry sump installed?
hello
thank you for pics!
The sump was on but the pump was not positioned in required manner so we set position and piped up. I'm not sure whether Roush dyno'd the engine with or without the dry sump setup installed or installed it afterwards...
