Hello:
It seems that LS7s are popular amongst builders in this community.
The oil pressure of the crate LS7 in my RCR40 is too low for safe operation at higher rpm (hot just 20 to 25psi at almost any rpm level above 1000rpm, tested at the sender as well; cold start ~80psi) The engine is from around 2007 and has about 2000km on it. The problem became very! obvious upon my first oil change using 5W30 oil. The engine will come out and be inspected for the source(s).
In the process of building up the engine I'd like to take the opportunity to make it race track worthy. I'm happy with the stock performance regarding hp and torque. I want to make it reliable.
Two questions:
a - Does anybody here have first-hand experience with the stock LS7 for track use?
(Similar to this: https://ls1tech.com/forums/generati...05-history-issues-ls7-engine-road-racing.html ?)
b - What upgrades would you recommend upon the rebuild? (I was thinking the Katech uprated oil pump, valve seat machining, new valve guides. Possibly the exhaust valves and a better sump (Currently I use the Aviaid baffle.) ? Also the con rods need attention regarding wrist pin tolerances along with blueprinting of the engine.
Greetings, Walter
Two questions:
Greetings, Walter
