Rover/holley 5 degree spacer, UK
Somebody has told me I need a 5 degree spacer to make my carb sit level? Anbody got one I can buy or point me in the right direction to obtain one?
Simon
Malcolm
I run one on my car. I think it may have come from Real Steel. I also run a heat sink plate under the carb to reduce heat trasnsfer from engine to carb. You may want to consider one of these. Keeping heat away from fuel bowls is a good thing. I have also lagged my fuel feed line. When you park up the fuel in the line overheats and vapourises so you kangeroo away next time you drive off! Embarassing.
Found it pm me.
