Curious about a Superformance car on ebay item #140276470839
The seller says its a one year old MK1, has motor and trans installed all ready to go. What Im confused about is his list of "updates and sorting" I've been told these cars are built really well? Im amazed at all the extra work he says he did. The aution ends in the next day so in case it ends and you dont have a chance to look at it here is a clip from the ad. Thanks for any input!
Updates and sorting:
* Halon Fire suppression system installed
* Air conditioning: fully sorted including electrical re-wired and all 0-rings replaced to correct leakage
* Fuel pump rewired to separate circuit
* Tow Hooks installed
* Rear Sway bars and exhaust headers modified to fit chassis, rear suspension travel and bodywork
* Shift linkage completely reworked
* Hydraulic throttle linkage installed
* Pedal Assembly repaired and re-constructed
* Front Sway bar and A-arms re-positioned for proper clearance and alignment and minimize bump steer
* Steering re-timed and all Heim Joints re-set correctly
* All under-amperage fuses, relays for AC and engine fans re-wired and/or upgraded
* And much more!
* And much more!
