I'm selling my Superlight Aero R and someone is going to get a heck of a deal. This is by far the most sorted and developed Aero in existence. This car has extensive upgrades and won 3rd in the SU class at the 2024 NASA Championships. It's an absolute hoot to drive! I'm basically selling this car for the price of the engine, transaxle, electronics and wheels - the Milspec wiring harness, brakes, battery, shifting system, steering system, suspension, radio antennae and harness, chassis, body, floor, wings, windshield, tools and spares are pretty much free. Price it out and you'll see what I mean. Full transparency - drivers over 6'2" in height should not buy this car as you won't fit well. Just sayin'. ;-)
This car is fully prepped and ready for the track. It's got fresh engine and transaxle oil and filters, the half shafts have been serviced and greased, the brake pads are have just one weekend of use, the front rotors are brand new, there's fresh vinyl on the body and a new Pyrotect fuel cell that's certified until 2030. The Lifeline Fire Bottle has been recharged as well and is good through 2027. This sale also includes the 2-piece mold we used to make the air intakes for the oil coolers, in case you want to make some out of carbon fiber. This vehicle has never been crashed or wrecked and comes with a lot of spares, tools and supplies (see the details below). Note that I have also listed it on racingjunk.com.
Here's the details:
This Superlite Aero R has extensive performance and safety modifications resulting in a very safe yet extremely fast race car. No expense was spared in building this chassis. When it left Superlite it went straight to Agile Automotive, where it spent over a year getting significant upgrades to the chassis in addition to mounting the engine and transaxle. From Agile it went directly to Veracity Racing Data for a bespoke milspec wiring harness, MoTEC installation and calibration and engine break-in and tuning. The pedals, wheels, wheel studs, master cylinders, steering column, steering rack, steering wheel, seat, water reservoir, water pump, battery, wiring harness, electronics, transaxle, shifting system, fire suppression system, floor, rear diffuser and rear wing have all been significantly upgraded. We used Goodridge G-Line XF 910 hoses and AN fittings throughout the car - this stuff costs $30-$80/foot. It also comes with Electric Power Steering, an AiM SmartyCAM, a custom carbon fiber air intake, two sets of Forgeline racing wheels with used Pirelli slicks plus a set of new Pirelli rain tires.
POWERTRAIN
CHASSIS
SUSPENSION
SAFETY
BRAKES
COCKPIT
DATA & ELECTRONICS
WHEELS & TIRES
INCLUDED TOOLS & SPARES
MISCELLANEOUS
Here's the details:
POWERTRAIN
- GM LS3 with Hot Cam 495 HP/475 lb-ft torque
- Part # 19370411
- Date of Mfg: 3/17/2019
- Serial Number: 19031405 4795
- Custom 303 Stainless Steel headers with HeadershieldTM and hi-flow dual exhaust
- Albins ST6-M six-speed sequential transaxle with LSD
- Part # 21250
- Rev: 200
- Serial Number: 38837
- Shiftec paddleshift-actuated pneumatic system with auto blipper
CHASSIS
- Steel tube, TIG-welded with side intrusion structure, aluminum front crush box
- 3-piece Fiberglass body
- High downforce GoodAero Carbon Fiber Rear Wing
- Bespoke carbon fiber engine air intake
- Bespoke engine and transaxle oil cooler air intakes
- Sculpted dual angle rear wing endplates
- Custom Shields polycarbonate windshield
- Custom rear diffuser by Hurley Racing Products
- Professional Aero Extreme Series Elliptical Mirrors
- Hurley Racing Products Custom carbon fiber floor extensions with side ankle cutters
- 930 rear axles
SUSPENSION
- Penske 7500 Series adjustable shocks. 1000# F, 1100# R springs
- Billet machined aluminum uprights and control arms
- Front and rear adjustable push rods
- Adjustable anti-roll bars; upgraded titanium rear ARBs
- Corvette C6 wheel hubs with ARP studs
SAFETY
- Pyrotect 24-gallon Fuel Cell w/Hydramat, FIA FT3 approved
- Fully boxed and triangulated 1 1/2" TIG-welded steel DOM tube frame chassis (FIA, NASA and SCCA-legal)
- Kirkey 45 Series Custom SFI Rated seat with BSCI SFI approved foam insert
- Schroth Flexi 2x2 6 Point Racing Harness
- Lifeline Zero 360 FIA 3.0kg Novec 1230 Fire Suppression System with 2 nozzles in cockpit and 3 nozzles in engine bay
BRAKES
- Front: StopTech ST60 6-piston forged aluminum calipers
- Rear: StopTech ST40 4-piston forged aluminum calipers
- Tilton 79 Series Master Cylinders (79-750 F, 79-625 R)
- Pagid Yellow Racing Pads, U-1903 & U-1204, RS29 Compound
COCKPIT
- Single seat, center position
- MOTEC C127 7” Color high resolution LCD display with programmable LEDs and 120MB Logging Option
- MOTEC 15 Button programmable backlit keypad with adjustable brightness and LED indicators
- Brake Bias Adjuster
- Sparco F10A 270mm steering wheel with custom panel with six programmable buttons and carbon fiber paddleshift levers
- Adjustable Electric Power Steering
- Sparco weld-on steering wheel Quik Release
- Carbon fiber dash panel with multi-position rotary switch
- Custom carbon fiber radio holder
- IMSA Digital Car Harness
- UHF Phantom Elite Antenna mounted in front of driver under dash cover
DATA & ELECTRONICS
- MOTEC PDM 30 Power Distribution Management with CAN
- MOTEC i2 Pro Data Analysis with GPS receiver
- MOTEC M150 ECU with GPRP Package
- AiM SmartyCam GP HD Rev 2.2
- Installed sensors:
- Engine Air inlet temp
- Engine Oil temp
- Engine Water temp
- Transaxle Oil temp
- Engine Oil Pressure
- Fuel Pressure
- Inlet Manifold Pressure
- Front Brake Pressure
- Rear Brake Pressure
- Throttle position
- Steering position
- Gear position
- Fuel Level
- Veracity Racing Magnetic Shock Position Sensors
WHEELS & TIRES
- 2 sets of Forgeline GA3R Wheels, 18”x10” Front, 18”x12” Rear
- Front tires: Used 285/645-18 DHB Pirelli Slick
- Rear tires: 315/680-18 DHB Pirelli Slick
- Overall Length: 186" with improved rear wing location
- Width: 74"
- Height: 40"
- Weight: Approximately 2170 lbs
- 1 Set Forgeline GA3R wheels w/used Pirelli P-Zero Slicks: 285/645-18 (F), 315/645-18 (R)
- NEW Shields polycarbonate windshield
- NEW Pagid Yellow front and rear pads
- Coil over spring pairs: 600#, 700#, 800# and 900#
- Starter
- NEW Battery
- NEW Rear brake rotors
- Camber shims (package of them)
- NEW Sway bar bracket
- Rear air intake molds
- Factory steering wheel and hub
- Factory electrical harness and switch bank
- Factory Rear Wing and Endplates
- Factory rear diffuser
- (2) factory lower rear a-arms complete
- NEW Wix Engine Oil Filters (9)
- NEW Albins ST6-M Filter Elements (8)
- Three (3) 90ci carbon fiber tanks with two foam lined cases for paddle shift system
- Albins ST6-M Drop Gear sets (.93 installed):
- .81
- .88
- 1.0
- 38MM box wrench for Albins ST6-M
- 3/8” Drive, 10MM deep well thin-walled 12pt socket for AlbinsST6-M
- (2) air compressors for paddle shift system
- NEW Pierburg Electric Water Pump
- 3 Hunsaker QuickFill 5 Gal. Gas Cans for Aero Fuel Inlet
- Polycarbonate side windows
- Spare pushrods with heavy duty rod ends
- Assorted hardware
MISCELLANEOUS
- Vehicle is at my home in Draper, UT
- You are welcome to see it
- Delivery is possible - happy to discuss. It might be best as I could provide an orientation session on the car. Otherwise we can do an orientation session when you pick it up.
