Hi guys,
Reaching out for some thoughts from your good selves re an oiled plug...
Am running an old 302 Windsor standard set-up...
Was told the engine was sound although had sat around unused for a while.... have started running the engine up and she smokes oil a bit and now have some intermittent clicking coming from one bank of rockers....blue smoke getting worse on acceleration...
Pulled the plugs and one cylinder plug shows oil traces...
Inserted a camera and small amount of oil sitting on top of the piston.....no traces of broken ring...
Compression test shows 130psi.....so not sure if this totally eliminates a stuck or broken ring but am hopeful that ring is intact.
So my question is could this be a fault with the valve steam seal.....?
I am a novice when it comes to engines but if compression is OK I am guessing the oil must be coming from above hence the question re the seals..... the on off tapping or clicking seems to be coming from the same bank/cylinder...
Would welcome any advise from you experts to a novice like myself and am hoping that replacing the valve seals is quite straight forward.....
Thanks for anyone able to help with some thoughts....
Kind regards
Marcus
Kind regards
Marcus
