Tire Rack for Garage
Sorry I have not responded to the posts or emails but I have been away for a few days.
Attached is what I ended up putting up and I'm very pleased with it. It is a tire rack kit you can get off Ebay for $80 and includes three supports made from 1/4" aluminum that have been drilled for various tube placements. The tube there is simply electrical conduit which is strong and cheap.
The ally supports bolt on the wall through six pre-drilled holes in the aluminum. I used some 5/16" 4" long lag bolts. You can adjust the spacing of the supports for your wall studs and/or the length you wish to make the rack. Mine is just under 9 ft from outside support to outside support.
Total cost is around $95 when you add in the tubing but it isn't a bad deal in my opinion. Extremely study and easy to use.
