Whats the advantage of having a tire with a stiff sidewall when you can add more pressure to a tire with a softer one? The hoosier's i last ran seemed to have way stiffer sidewalls than kumho victoracers; and when i ran the hoosiers at the same pressure that i use to run the victoracers at, it was way to stiff with the tires bouncing over every imperfection.
So, the solution was to just lower the air pressure. But then, its seems like its an equation where the 2 sides just cancel each other out: Stiff sidewall? take out air. Soft sidewall? add air!
I know they say that your supposed to get more responsive handling and better turn in with a stiff carcass, but it seems like i can get that by adding more air. Again, its back to the equation.
The only things i can think of is that a stiff tire sidewall has a different springrate than air, and could possibly control the contact patch better than a soft sidewall with lots of air, and maybe require less camber? Or, maybe stiff sidewalls have some sort of damping property to them; so its like having a tire with lots of air, but without the uncontrolled bounciness that would require more damping from the shock?
Anyone have any thoughts on this?:huh:
