Transmission cooler
Hi
I have just secured a build spot for a mk11. The dealer is saying that a transmission cooler is not necessary unless you're going to be racing the car hard. He also said that they are very noisy. At this point I have not ticked the option box but definitely will do if recommended by owners. Car will not spend much time on a race track.
Assume you have an SPF with RBT (or ZF) trans on order? You don't need a trans cooler. I did many track days without a cooler. Only if you're on track for more than half an hour might you need one.
