Transmission Paint
Hi Pat , I would think 300 degrees would be more than enough.If its not I would think your box is about to lock up! Stuff looks nice to me too. Hope your build is coming along well. /ubbthreads/images/graemlins/tongue.gif
Chris,
Hi temp, wrinkle paint actually dissipates heat better than
smooth paint or a bare surface, as it creates a larger
surface area. Wrinkle paint has been commonplace on high
performance motorcycle engines(all aluminum) since the
early '70s. It should work just as well on a gearbox, if
heat is THAT much of an issue.
Pat,
I painted my gearbox with a silver, high temp paint(smooth)
3 years ago, and haven't noticed any change in temperature
since. The silver color looks like anodized aluminum, and
hasn't changed a bit due to heat cycles. $5 from Carquest.
Jim Dewar
I remember asking a radiator repairman what paint they used in finishing their radiator repairs. He replied that only lacquer paints could be used. Enamel paints would insulate and reduce cooling. Just an interesting fact from years ago. May not apply to modern day paint.
Thanks guys. I'm not worried about insulating the surface as I don't see that happening with these types of materials. I just wanted to see if there was any experience out there with this type of paint.
