Sorry about the bad Link try this one Here Once you get into the site go to galleries then construction and then to Technical gallery hope this helps. If you use a distributor you will need a side access through the box. Rear vacuum line PCV valve has been istalled internally.No hose on my manifold but there is no problem running a line under the the cold air box as i did origonally have mine fitted this way. Email me if you need any more Info
In the gallery section there is a thumbnail for all the galleries in the centre of the window on the screen, move the mouse over it a tab will highlight, click on the highlight to go to all galleries.
