UN1 bearings
Kevin Box
Can anyone help with supply of the following bearings - not available in Australia
NTN/SNR number_____Renault_OE_number_ID________OD___________Width
N.10755 S02________7703090208________25.00_____47.00_________14.00
GB 10827 S02_______7703090207________25.00_____62.00_________28.00
RNU.10705_________7703090177_________43.00_____80.00_________24.00
FC 10893__________7703090245_________28.00_____67.00/75.00____45.40
Also I need an Input shaft seal
If any any of the part numbers are incorrect I would appreciate any corrections
Thanks in advance
Kevin B
Kevin, I sent a private mail through to you. I took a set of mine down to the local bearing supplier and in his words 'there are sh1tloads in Australia' according to him.
Check out my email.
Kevin Box
Thanks Bruce
I tried CBC bearings who are usually pretty good but they could only supply the input shaft bearing soo at least i have one of them now.
I also tried Saeco in NZ with no luck
Maybe I need to try some other Australian suppliers
At the moment the only people able to supply are in the Ukraine but would prefer to purchase local if at all possible
Bearings.co.uk sent me polite email reply that they don't send outside of Europe which I found a bit insulting as neither NZ or Australia are third world countries.
Other places I have not managed to connect with are GTO and Chris Cole so still have a couple of options if local contact does not come through.
Cheers Kevin B
If you come across that crap just shout and use my Uk address and I will ship them out.
Still I believe Chris Cole would be your best bet!
