Hey guys -
So I have the new FiTech surge tank/pump installed but I’m having startup issues, not sure if it’s all fuel related or if there’s something electrical going on too.
First issue - fuel pressure fails to stay at 60psi after my pumps prime. Cycle the ignition, pumps prime to 60psi, then shut off. Pressure should stay high and it bleed down for a while - I deleted the Bosch 044 pump and I believe this pump was keeping pressure in my system.
I installed a new check valve between the new HP pump and regulator but pressure still fails to hold. I pulled the new check apart and it’s a pretty wimp rubber flappy valve - I can blow into it both ways. So it’s basically a crappy valve and my pressure not staying up is likely that. I’ve checked for leaks and there are no external leaks right now.
OK - so fuel pressure is too low to start the engine. I have been able to jimmy the engine to start by cycling the pumps, waiting a few seconds, then engaging the starter. I’ve been catching the pumps right as they hit 60psi and the engine will start and idle just fine if I do this sorta 2-step start sequence. Doesn’t run rich, no surging, idles normal. ISSUE. The throttle is non-responsive when I do this startup routine. The engine idles and giving it gas does nothing. The ETC position readout on my dash says 0% which is what it reads when I don’t have my foot on the pedal.
Ok, so potentially an issue with ETC wiring right? Well if I just cycle the ignition and don’t try to start the car I can modulate pedal position and get ETC readings like normal and I can hear the throttle blade opening and closing (when the engine isn’t on).
During this whole fuel system troubleshooting thing the only electrical thing I did was to re-wire my fuel pump signal.
Old setup - fuel pump wire from fuse box, split into 2 wires, fused, then into the each pump.
New setup - fuel pump wire from fuse box, goes into 2 relays in parallel then signal passes they a roll-over/shock sensors, then ground. So the only load that wire sees is from the relays. The relays draw power from a +12V junction block, 1 wire into each relay then on to a pump.
I’ve taken the shock sensor out of the equation by pulling the harness and jumpering the leads, no change in how the car behaves during startup.
So 2 potential issues happening here, I’m wondering if the ETC not responding when the engine is running is a clue. I have a new check valve on the way, hoping that addresses my peiming pressure issue. But even if I can get 60psi to the rail at startup I’m concerned the ETC issue will continue to plague me.
Low voltage? I’m seeing 12V on my dash before cycling the starter, don’t know what it’s dropping down to during the start cycle. Have the battery on a tender right now.
Is the low load on the fuel pump lead coming from the fuse box an issue? Can’t think of why the system would care about low load on the wire but throwing it out there.
Anything else to check for?
