What is your Set up ?
Hello
I am looking for a good set up To drive on the road for my gt40 tube châssis tornado.
What is your géomètry?
May i have caster angle, toe setting etc..
Many thanks
Mathieu
Mike Pass
These are the settings for a GTD. The Tornado uses very similar suspension so these should be a good starting point
GTD Tyre pressures and suspension settings
Tyre pressures
Front 21psi
Rear 23psi
Ground clearance Front 4" Rear 4.5"
Front toe in 1.6 – 3.2 mm overall
Front Camber 15’ negative (0.25deg)
Front Castor 3deg 20min positive
Rear toe in 0-1.6mm overall
Rear camber angle 30min (0.5 deg)
