These are the settings for a GTD. The Tornado uses very similar suspension so these should be a good starting point
GTD Tyre pressures and suspension settings
Tyre pressures
Front 21psi
Rear 23psi
Ground clearance Front 4" Rear 4.5"
Front toe in 1.6 – 3.2 mm overall
Front Camber 15’ negative (0.25deg)
Front Castor 3deg 20min positive
Rear toe in 0-1.6mm overall
Rear camber angle 30min (0.5 deg)
