Wheel Bearing Seals / Spindles
Has anybody ever had a problem with their wheel bearing retaining nuts coming loose? There is a retaining ring with a tab that fits into a slot on the spindle. I have had problems with mine and was curious how commonly the situation occurs. When this happens it usually trashes the wheel bearing sealing rings.
Thanks,
John
John,
Several owners blue Loctite the screws. I also changed from button allen heads to hex head screws on the front ones to get better torque. Not sure hex head screws will clear things in the rear.
