What tranny and gearing are you planning to use with that high reving (twin turbo?) 20b grenade?
G50-50 and most likely stock gears to start with to see where I'm at and what I/engine really needs.
The stock twin turbos are very small and are limited to about 400 rwhp. They just run out of breath.
Grenade? Let's hope not
Also, could you share the specs of your planned motor - sepcifically, the weight, output and length?
Lightened, race clearanced rotors and balanced rotating assembly
3mm 1-piece ceramic apex seals w/ hardened & micro-polished springs
Mazdaspeed dry-sump front cover and oil passage modifications
3/4" thick billet aluminum sump plate w/ (soon to be) integrated mounts
Large street port
Right now I have a GT4202R w/ T6 turbine housing w/ 4" exhaust...for now. I may sell/upgrade it and get a billet comp wheel that flows more without the drawbacks of going to a larger wheel. Also available now are v-band stainless turbine housings that would weigh much less than the monster T6 housing that I currently have.
I may also be getting aluminum side housings and/or going with a bridgeport. Aluminum side housings will save 45 lbs. The ports are like the lift/duration of a cam without all the useless parts of the valvetrain. So a bridgeport is pretty much like like a high lift long duration cam with more overlap.
Power projections:
Streetport 750 hp on 91 octane
Bridgeport 850+ hp on 91 octane
With a nice tune, the motor as stated should last a very long time at those power levels. There are plenty of them running and they've proven themselves. Besides the apex seals, the factory e-shaft is the weak link in a 3-rotor. There is an aftermarket billet shaft available but I don't plan on running the power levels to break the stock piece.
If that much power is more than required, contrary to some "expert opinions," a 20b could be run at lower boost (making ~450 rwhp and create far less stress on the engine when compared to a 13b at the equivalent power level and with more torque.
Not decided on an ecu so far, though not cheap, Motech is always an option. Haltech has a new ecu out too for less money but I haven't looked into yet as I'm not at that stage yet.
I've looked at rotaries before, and the Power/Weight ratio looks unbeatable on paper. I just wonder why more "enthusiasts" don't run them in lightweight cars...
They do, you just don't know about them
That said, it is cheaper and certainly easier to put an LSx into something. The engines are a dime a dozen, reliable and simple solutions for the simpletons
Internal block defect - see above for illustration.
There is no block, hence no defect...blockhead
Paul, It's cost. I have about $3500, with it headed towards about $4500 total, in my 350 chevy. I expect 450Hp but fear more like 500+. A proper 450HP rotary is in the ballpark of $20K. You can build a lot of performance with $15,000 extra to spend.
If dollars are your main concern, Howard's reasoning is hard to beat even if a 450 rwhp turbo rotary could be built for WAY less than 10k...which it can.
And by the way there,s not more than 60-80 pounds difference between a 4 barrel alum head SBC and a turbo/intercooled 3 rotor if you include all of the pumbing/etc. weight.
Possibly, but there are way too many variables to make such generalizations.
HP is HP given a(n) equal weight.
It's all in the journey.
I think that the Apex Seal problem can be solved by running the car on E85, as that makes the engine run cooler due to the lower combustion temperature of the fuel. This along with the ample room for extra oil coolers should keep this engine in check while it's set inside the SL-C.
Lots of guys running E85 with great results. The apex seals are only a problem if you have other issues leading to their failure, all of which are preventable.
So, to summarize, the issues are:
1) Cost,
2) The weight savings aren't really there, and
3) There seems to be a complexity issue as well.
1. A turbo rotary
could cost more and most likely would if it is going into a car like this. Depends on the resourcefulness/budget of the builder really.
2. When all is said and done, I am hoping my turbo 3-rotor will be 40+ lbs lighter than an LSx if I use the aluminum side housings. A 13b, with the same housings could be ~90 lbs. lighter.
3. The complexity would be the same for any turbocharged engine which will always be more than an n/a engine.
It seems to me, that the rotary is perfect - in a certain HP range. Once you start trying to get over 200 - 300hp (figures from rotaryAviation), the cost, weight and complexity of the Mazda rotary starts to increase.
They are refering to the n/a vs. turbo debate in airplanes and the serious lack of packaging room they have to work with. No such limitations with an SL-C. Granted, a turbo system is more complex than if it didn't exist at all :shocked2:
"Ballpark ideas" on pump gas:
13b n/a......200-350 hp
13b turbo...300-600 hp
20b n/a......300-550 hp
20b turbo....300-850 hp
Cost, (weight and complexity to a point) of any engine goes up as power levels increase.
LS3, as Fran recommended, looks like a good balance.
LSx is the best choice for
any swap, in any car, hands down.
Now I better get off this forum and get some real work done :thumbsdown:
