What torque is recommended for the clutch pressure plate bolts?
In Allan's video, he mentions 25 ft-lbs, but this is much higher than the normal recommended torque for 6 mm bolts.
Also, the bolts I was planning to use are grade 8 hex head, but in the video, Allan is using socket head. I think socket head bolts are normally grade 12.9, so this helps, but even a 6mm grade 12.9 bolt normally carries a maximum torque of only 12 ft-lbs; half of the value Allan references.
