I ordered the 347 stroker w/webers. They said they could supply 48 IDA's in place of the IDF's . Well that never happened! after 2 mo. of waiting I had them put a holley on it so I could move forward. Motor dyno at 435 hp. ran great . A little valve noise prompted a valve adjustment. This is when I noticed poor rocker tip too valve stem allignment. Removing the rocker showed a sloppy needle bearing fulcrum. infact the fulcrum shaft slides easly in rocker body. NO GOOD. Next I noticed one of the rocker nuts was down lower than the rest! Took that rocker off and it was missing the push rod cup. It was adjusted and didn't make any noise.
Bottom line at the verry least POOR QUALITY roller rockers. I think they are Pro Comp brand, that is made in China...
But more importantly the guy that put this motor together was a sleep.
Hellow you would notice the drastic adjustment difference, or I would have noticed it. I assume you get the fact I am pick mother f-er, but come on!!
I Know T&L has cheep prices, but anyone waiting on a motor ,call and upgrade their rockers at least.
Any with one of thier motors heads up. I only have 25 mi. on this motor. The 3 worst rockers had aleady scraped through the red anodising and you can feel where the nuts were eat the sides.Loose Fulcrums
Glad I looked!!!The question is : am I going to be able to sleep with out checking the whole motor!!!
Randy
Randy
