Explanation please :thumbsup:
Venturi effect is sorta like the opposite of ram air effect. When air goes around the vehicle, it creates a higher pressure airmass. When it breaks away from the car (especially at the rear), that portion not in the airstream is regular atmospheric pressure. The regular airmass gets "pulled" toward the passing higher pressure.
If you have a hot engine bay or some sort of cooler that you want to pass air through, this effect will help pull the air through or out of the low pressure area. This idea is widely used on aircraft for exactly this purpose (extracting heat).
Here is a simple test: take a sheet of paper and hold it on the corners of the short side with your thumbs and index fingers. Let the paper drape over normally. Now blow on the bottom, you expect the paper to rise and it does (ram effect). Here's the cool part, blow over the top and the paper will rise too
Clear as mud???
