Hi I have bought a 930 and a adaptor kit to bolt behind the 302W,the adaptor is a great fit.
The flywheel is machined for the G50 Presure plate ,I am having a had time making the 930 thrust bearing work as the G50 bearing is smaller in the middle,and the 930 fits the gearbos shaft but wont fit inside the Presure plate,its around 4mm larger Diameter,do I need a adaptor?
Thanks Martin
Thanks Martin
