KEP/G50 Pilot Bearing
I just ran across some of my notes from my Black Mirage build and I thought I'd pass on this little bit of information.
My build uses a KEP adapter, clutch, and pressure plate mated with an inverted Porsche G50. The engine is an aluminum-block Donovan (SBC) but the KEP flywheel for a Ford is probably the same.
My experience with Bronze bushings has been spotty so I searched for alternatives. I found a double- sealed Delco ball bearing 949100-3190, 9491003290 that is 15mm x 43mm x 13mm. It is listed as an "alternator bearing" but it is working just fine.
