Jack,
Thanks, I thought so.
Another question.
Can you describe the actual operation of your system for me. Specifically:
From your description above you seem to have the solenoid and 35/40# pressure swich set up.
I'm trying to understand the relationship between the pressure switch and the solenoid during pre oil AND surge operation.
For first cold start: Assume accusump is air pre charged to say 10#, and wheras engine oil pressure is 0 (under 40# when your swith closes) the NC pressure switch is open energizing the solenoid open allowing start up oil pressure to enter the accusump (say engine oil pressure will be 70# for a baseline). Now my question is as the system pressure rises above 40# does the pressure switch close not allowing the accusump to fully charge to the 70# engine pressure and if it doesn't close why not?
What do you see on your accusump gauge when you go from engine off to a cold start? Assume you have 70# does your accusump discharge to the 10# precharge and then recharge to 70#, do you see a surge to 70# on your dash oil pressure gauge on cold start as you hold key on before cranking and before oil pressure rises as engine starts to the 70#? If yes I don't understand the operation of the 35# opening, 40# closing pressure switch.
Bonus question re "surge" function. If <35# the NC press sw elex opens and opens the solenoid but then shuts again at 40 how does the accusump reach full system charge?
Do you or does anyone else have a handle on theis?
Tx, Steve P2125
